A few days after Power Up’s Kickoff, I found a loophole that would have helped win almost every match. At least until other teams saw you play and the referees changed the rules. My mentor said we could reconstruct our robot if we qualified for Worlds, but I decided we were better off as we were, and so I’ve decided now to reveal the monstrosity I call 27 foot bot.
The name says it all. This robot would quickly drive over till it was inline with the opponents platform zone, against one of the side walls, knock itself over, and extend 27 feet across the field, to the opposite wall. This would trap the opposing alliance, either starving them for cubes, or locking them into an area with just their own switch, allowing your own alliance to receive double the ownership points and a massive advantage.
This is possible due to a few oversights in the rules. Robots were not limited on height extensions this year. Their height dimension is based off their starting configuration. G12 was written in regards to the original way the null zones were defined, and stated that you couldn’t collude with alliance partners to shut off major parts of play, as in place one robot in each null zone. Luckily, with 27 foot bot, you would only need one robot. Even if another robot wanted to push you, they’d be encroaching on the vertical extension of your frame perimeter, and receive a yellow card according to G11.
Unfortunately, this idea never saw fruition, and was just a dream to be shut down by rule changes after its first couple matches.
Your problem would have been S01, I would call a robot that has both the ability to extend 27 feet upward, and the ability to tip itself over, a dangerous robot
Really cool idea though! I always love to see brilliant strategies.
I’ll let others figure out if this does break any rules, but it would be a completely ineffective robot. The positioning would have to be fairly precise for the robot to interface with the opponent’s switch without risking pushing down on a cube on top of the switch. At least two of your opponents would be at center field after auton, and seeing your 27 foot robot coming, they could choose to leave only one robot in the home zone for switch and exchange with the other two doing portal runs. Meanwhile, your alliance is down an entire robot with no access to your own portal. It just doesn’t give an advantage fast enough to prevent the opponent’s from responding and addressing it.
G10. Don’t tear others down to lift yourself up. Strategies aimed at the destruction or inhibition of ROBOTS via attachment, damage, tipping, or entanglements are not allowed.
This could probably be called. Doesn’t say you have to be tipping the other robot.
C01. Egregious or exceptional violations. In addition to rule violations explicitly listed in this manual and witnessed by a REFEREE, the Head REFEREE may assign a YELLOW or RED CARD for egregious ROBOT actions or Team member behavior at the event. This includes violations of the event rules found on the FIRST® Robotics Competition Event Experience web page. Please see Section 10.7 YELLOW and RED CARDS for additional detail.
You might get away with it for the first match. But seeing it was an intentional strategy, I would bet the Head Ref would get on the phone to HQ and give you a red card pretty quickly after that. Furthermore, I would make the argument that a robot designed with that strategy in mind would be violating a number of other rules. The key here is that it’s part of your team’s strategy and game play, not a robot accidentally tipping over. G07, as your bumpers would no longer be in compliance when in that configuration. G05 as you would be in an illegal playing configuration (For a historical note, look up flop-bots from ~15 years ago - robots designed to start the match in one orientation, then fall down to play in a different orientation).
I thought about this, but G13 is really a special protection for tipped robots. Not even bumper-to-bumper contact with a tipped robot (<10 seconds) is allowed, so I think that’s the only protection that goes away after 10 seconds.
Instead, I think the core rules problem is with R24 (bumper zone). If tipped-over is an intended configuration of your robot, then your bumpers need to be within the bumper zone when your robot is in that configuration.
Hmm…? A loophole within the loophole? FIRST likely intended this as tipping other robots. However it, combined with C07 is probably what holds this robot back.
Except that they would be encroaching on the vertical extension of your frame perimeter according to G11. This would probably go to a decision at the referee’s discretion on C07.
I agree. The downfall of this bot would be a quick rule change. However you do get one match of glory for $15,000. I don’t see anything in G05 about playing configurations. It’s possible the rules have been rewritten over 15 years. Extensions are based on your robots starting configuration. I also don’t see how this would violate G07.
R24 states that the bumper zone is defined based on a virtual plane parallel to the robots frame perimeter. If the robot tips over, accidentally or intentionally, its bumper zone tips with it. G05 doesn’t apply to height extensions as the frame perimeter exists only on the x-y plane.
You need to look at this situation from what certainly would be FIRST’s point of view. We have one robot that is preventing other teams from playing the game.
Even if they had to rules-lawyer something afterwards, your bot would be deemed illegal after one match. Perhaps even during inspection if you shared your intent. They would not let a strategy like this ruin the game play for numerous other teams. It’s risk management. Prevent one team from playing, or prevent dozens. Easy choice.
Always remember that when looking at something like this. FIRST reserves the right to basically do whatever they want. It’s not fair, but there it is. They might couch it in rules speak to appear to be following the spirit of the game, but either way you’d get thrown out.
The bumper zone is defined 'in reference to the ROBOT standing normally on a flat floor" (quoted from R24). If you’re intentionally tipping over, “tipped over” is one of the ways that robot stands normally on a flat floor.
I see they faced each other and 68 came out on top. Would have been interesting to see the race to deploy each. We managed after a sustained amount of ramming to dislodge and twist 118. I can only imagine the damage to this hypothetical 27 foot robot, that doesn’t really have a clear way to anchor itself. Also, I think it would be twisted enough to get heavy penalties during end game. Also, I think it breaks enough rules to be outlawed for Power Up.
C01: Egregious or exceptional violations. In addition to rule violations explicitly listed in this manual
C07: Don’t expect to gain by doing others harm. Strategies clearly aimed at forcing the opposing
ALLIANCE to violate a rule are not in the spirit of FIRST® Robotics Competition and not allowed.
Rule violations forced in this manner will not result in an assignment of a penalty to the targeted
ALLIANCE.
Violation: FOUL. If egregious or repeated, TECH FOUL and YELLOW CARD.
G13: If an opponent’s down, back off. Fallen (i.e. tipped over) ROBOTS attempting to right
themselves (either by themselves or with assistance from a partner ROBOT) have one ten (10)
second grace period in which they may not be contacted by an opponent ROBOT. This protection
lasts for either ten (10) seconds or until the protected ROBOT has completed the righting
operation, whichever comes first.
Violation: FOUL. If intentional, YELLOW CARD.
Looking at G13, you’d lose your protection after ten seconds. At that point, the rule opens up contact even if it’d violate G11. That prevents them from taking a penalty for contacting you.
I’d see C07 here as it’s clear your action is a strategic attempt to draw that foul. Wouldn’t that apply egregious even if they didn’t make repeated contact? That’s a quick yellow card.
With C01, while your actions don’t meet the definition of blockading on their own, you meet the intent. It’s not difficult to call that egregious for a second yellow card, escalating to a red.
Another quick mention, referees don’t write rules. They’re tasked with reading, understanding, and enforcing the rules the GDC write.
