Warning at edu.wpi.first.wpilibj.IterativeRobotBase.printLoopOverrunMessage(IterativeRobotBase.java:412): Loop time of 0.02s overrun
Unhandled exception: java.lang.IllegalStateException: A CANSparkMax instance has already been created with this device ID: 2
The robot program quit unexpectedly. This is usually due to a code error.
The above stacktrace can help determine where the error occurred.
See Reading Stacktraces — FIRST Robotics Competition documentation for more information. -
Error at com.revrobotics.CANSparkLowLevel.(CANSparkLowLevel.java:157): Unhandled exception: java.lang.IllegalStateException: A CANSparkMax instance has already been created with this device ID: 2
at com.revrobotics.CANSparkBase.(CANSparkBase.java:194)
The startCompetition() method (or methods called by it) should have handled the exception above.
at com.revrobotics.CANSparkMax.(CANSparkMax.java:47)
at frc.robot.subsystems.SwerveModule.(SwerveModule.java:45)
at frc.robot.subsystems.SwerveSubsystem.(SwerveSubsystem.java:15)
at frc.robot.commands.autoTop.(autoTop.java:30)
at frc.robot.RobotContainer.getAutonomousCommand(RobotContainer.java:127)
at frc.robot.Robot.autonomousInit(Robot.java:80)
at edu.wpi.first.wpilibj.IterativeRobotBase.loopFunc(IterativeRobotBase.java:345)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:131)
at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:365)
at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:453)
at frc.robot.Main.main(Main.java:27)
Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:379): The robot program quit unexpectedly. This is usually due to a code error.
Error at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:386): The startCompetition() method (or methods called by it) should have handled the exception above.
********** Robot program starting **********
NT: Listening on NT3 port 1735, NT4 port 5810
CANSparkMax object created for CAN ID 10, which is not a SPARK MAX. Some functionalities may not work.
Warning at com.revrobotics.CANSparkMax.(CANSparkMax.java:50): CANSparkMax object created for CAN ID 10, which is not a SPARK MAX. Some functionalities may not work.
at frc.robot.subsystems.ArmSubsystem.(ArmSubsystem.java:14)
at frc.robot.RobotContainer.(RobotContainer.java:35)
at frc.robot.Robot.robotInit(Robot.java:36)
at edu.wpi.first.wpilibj.TimedRobot.startCompetition(TimedRobot.java:107)
the parts that talk about duplicate sparkmax, I looked but couldn’t find anything, can anyone help?
