There is a problem with my code please help
#include “WPILib.h”
#include “Commands/Command.h”
#include “CommandBase.h”
#include “Logger.h”
class CommandBasedRobot : public IterativeRobot {
private:
// Command *autonomousCommand;
Logger *logger;
virtual void RobotInit() {
	Logger::GetInstance();
	CommandBase::init();
// autonomousCommand = new DriveWithJoystick();
virtual void AutonomousInit() {
// autonomousCommand->Start();
virtual void AutonomousPeriodic() {
// Scheduler::GetInstance()->Run();
virtual void TeleopInit() {
	// This makes sure that the autonomous stops running when
	// teleop starts running. If you want the autonomous to
	// continue until interrupted by another command, remove
	// this line or comment it out.
// autonomousCommand->Cancel();
virtual void TeleopPeriodic() {
	logger->Log(Logger::kINFO, "In TeleopPeriodic()");
	logger->Log(Logger::kINFO, "Starting Sweeper");
	CommandBase::sweeper->run();
	logger->Log(Logger::kINFO, "Starting Conveyor");
	CommandBase::conveyor->run();
	CommandBase::drive->driveWithJoystick(CommandBase::oi->getLeftJoystick());
START_ROBOT_CLASS(CommandBasedRobot);
The issue is that one wheel works which is the left wheel. I cant get the sweeper to work or the other wheels
Im also getting a error the I/o unity not detected or not installed correctly
Check that your digital breakout board has power- there should be three green lights on it. Does your robot signaling light work? (or whatever it’s called, the big orange light)
Okay that all works
Well, I have no idea. good luck, and remember that code does not ship with the robot!
You didn’t post anywhere near enough code for us to help you figure out what’s wrong.
The “I/O unit” message is just informing you that the Driver Station didn’t detect a Cypress PsoC connected via USB. If you’re not intending to use one, you don’t need to worry about the message.
