Don’t use bad PWMs. Also, don’t connect PWMs backwards.
never trust the robot when its on
we lost connection with it and it went after the whole team
robot+lose connection=sprang ankle and no more camera turret
don’t forget when your working on it to put it on blocks…::ouch::
Neophyte team member sent to deburr a hole in a plate… 30 seconds later, we hear a loud sound and I spend the next 30 minutes extricating said plate from deep within the belt sander…
DO NOT! go up to your team’s CAD computer and decide it would be funny to mess around with the design. While fixable with ‘undo’ or ‘ctrl z’, it is really annoying and not remotely funny. One time a rookie even accidentally caused the computer to freeze up, making me have to re-CAD everything I had been working on
Do: Constantly save your CAD drawings
This happened to us a week ago. If you need to drill holes in a plate, and the holes are right above an encoder, NEVER EVER drill them without removing the plate!!!
That encoder took too long to replace
Do not try to see if the battery fits and accidentily touch the battery terminals to the frame causing sparks and the unfortunate nickname of Sparky.
Also do not forget to put the tailgate up on the truck you are hauling the robot in. You will make a turn and the robot will fall out on the highway.
Do: Insulate your batteries the INSTANT you get them. I thought everybody did that…
We had a 2-cim shooter setup, and wired the positive wires from each motor to one jaguar, and the negative wires to another! Thankfully, the jags survived and seem to have avoided any damage.
We actually did a similar thing, putting power into both sides of a Jaguar, and found that it was unresponsive afterward.
Don’t wire motors directly into the power distribution board and turn the robot on.
Don’t let freshmen drill on your electronics board by hanging it over the table when you aren’t looking, causing a giant crack to form in the Lexan you and your squad spent hours working on making the biggest, best board we ever made… in Week 6.
Why me.
Never ever EVER let the mechanical engineer guys design places for electronics to go and wires to go. They will put it under a giant rotating arm and make it impossible to wire anything there. Always design it yourself or find a place and be firm about it.
i put a wire connected to a bettery, much smoke. then a friend did it to prove what happened, and he got in trouble for it!:yikes:
Never forget to secure the robot crate in the back of a pickup when driving. It will fly out of the truck.
Nothing more bizarre than watching a 400lb crate catch wind and lift up and out of the trucks bed. Also, the truck stops faster than the 400lb crate sliding down the road, it rear ended me.
Robot survived.
My reputation didn’t
Don’t trust your non-driver friends with the controls for a moment. You think they won’t shoot you in the face, they will.
Leave the driver station on only the Classmate or not make redundant backups. Ours failed on the day we were supposed to have driver training, which led to a mess particularly because we had lost the LabView install media.
I’m sorry, but that video was hilarious!
Don’t put your #25 master links next to a tool set; when that tool set falls over and hides the master links, a frantic 30 minute search occurs. :yikes:
Plugging your 5 volt camera in to a 12 volt supply. We don’t know who did this… it might have been me… probably was me…
^^ Did that this year except it was an electrical engineer that decided to put it there! He didn’t quite think that one through.
Don’t force motors to turn :x
