Can anyone tell me who supplied the wheels in this years KOP’s. I called Skyway and was told “not us”.
www.andymark.biz is the supplier in question. Look on the edge of the gray on one side; the word “AndyMark” is molded into the plastic.
They’re supplied by AndyMark. www.andymark.biz
it was andymark… you can order replacements at andymark.biz
lol in the time it takes me to verify it actually was andy mark two other people posted… :eek:
Can we order 8 inch wheels from Andy Mark that were like 2007 wheels or do we have to use the wheels supplied this year? We need 8 inch wheels not 6 inch. We need just 2 to match some others we are using.
Thanks,
Carolyn Hinckley
No, Andymark only supplies 6" wheels. You can see what they have at www.andymark.biz
Are there any limitations on wheels used?
No. COTS wheels typically don’t cost anywhere near the $400 needed to make them illegal.
Only limitation is that no metal or velcro-like material contact the carpet.
i dont like the andymark wheels this year that came in the kit. they were all hard compared to last year which were soft and they actually sink in the middle like a u shape. we would have to put them on a lathe to fix them. anyone else have those problems.
Once you put the robot’s weight on the wheel, it spreads out to a larger contact patch. By lathing it down, you’re actually decreasing the effectiveness of your wheels… Also, teams using the AM kit wheels should probably get some advice from the longboarding world on how to break in 'Thane wheels. You can make a hard wheel extremely slippery, or incredibly soft and grippy, all depending on how you wear it in.
If my team didn’t have a decent budget, the AM wheels would be an instantly used item, as they are awesome for their price.
Skyway can provide 8" wheels like the ones first use to put in the kit. You will have to make adapters to use skyway wheels. In my opinion the rubber is much better on skyway. The andymark wheels are sloppy But you don’t have to make hub adapters.
Thank you so much.
Carolyn Hinckley
Hi, so the only rules that govern what wheels we can use is the price, that they are COTS and that they do no damage the field?
If we buy new 8" Skyway wheels and modify them is this still legal?
Thanks
Windell
#2477
I believe last year we were supplied with Andy Mark wheels as well, its been two years since we had Skyway wheels now. The AM wheels with the mounting holes for sprockets are a big improvement over the skyway wheels from the past.
Yes you can modify them. Use them as is if you want, but I would recommend getting them with the precision bearings to match your axle diameter. The stamped bearings will fail. Prices are very reasonable. You will need to make adapters to drive them and space chain if you use chain. I believe Innovation First made hub adapters that still might be available that make it an easier mount if you use chain and sprockets. They were in the KOP when Skyway wheels were offerred.
PS – AndyMark still has stock (last time I looked) of last year’s wheels available, which ae softer. Hoevr some of them faled at he bearing and/or spoke areas, and were beefed up for this year’s version. We modified them by filling in the hub space with epoxy/fiberglass to take the hard side hits that caused the bearing to break out of the hub rim.
i been posting for a lil while and i got a bad rep from the post i edited
IFI has high traction wheels that you can get in 8"
getting four of these runs pretty costly at $335.36 for a set of four wheels, bearings, 22 tooth sprockets and tread.
these are expensive but are very, very nice and work well
Does anyone know where I can purchase the skyway wheels? I took a look at the skyway site and it doesn’t seem that they have the 8" with precision bearings.
Please correct me if Im wrong. Thanks!
