Personally I don’t see the value due to lost intaking width and internal robot space lost, but I wanted to see what you guys thought?
High curve, but when overcome, great benefits.
See 4481:
See 95:
check out 95s latest CAD in their open alliance thread which has a solution to this issue, I think it has its advantages and disadvantages, but it does seem completely viable.
we’re currently prototyping an under the bumper intake… there’s a couple advantages. First of all, there’s a lot less moving parts compared to an otb intake that you have to extend and retract. Also, in terms of speed, your under the bumper intake will almost act like a roomba (discounting time to align). You save time from extending/retracting. It also centralizes your center of mass, which is great for moving fast and staying stable, and playing defense.`
You already listed some of the disadvantages. I will add to that list that you do not see a gamepiece as it’s being picked up. That means if you go over a not with the wheel, and intake grabs it as well, you may need a few moments to “untangle yourself”, and that’s loss of game time.
Also I am not sure you will have less moving parts unless you’re going with the fixed angle shooter, which limits your range and abilities. And if you have a movable shooter, such intake may not help you with the cycle time.
So far we decided against the under-bumper intake for all these reasons.
It’s a lot harder to break an under the bumper intake from robot collisions. Even the best teams struggle to make intakes which never break and intakes breaking was a reason that a ton of teams lost matches at champs.
I figure it’s also possible to supplement an under the bumper intake with a intake that goes over the bumpers but passes the game pieces under the bumpers, if acquisition zone becomes a problem.
Edit: especially if you plan to play chicken:
For the tangled protion of your concerns. I would think you could add skirts to the bottom of the robot frame to help prevent getting tangled on notes.
Depending on that, it could end up worse, where the note gets stuck more than without (see 2020 power cell discussion).
That would help, but my concern then would be trapping the note - which is very squishy- between the deflector and the wheel.
