Throttle Motor
Has anyone used Throttle Motor Denso AE235100-0160 on their robot ? If you have what function did you use this motor for ?
Thanks VIKotic/ SciBorg Dave
In 2012, 469 coupled it to a small leadscrew to tilt the shooter up and down.
For what it’s worth, every inspector we had that year told it was the first time they’d seen someone use it on their robot.
Well that was the first year it was legal :stuck_out_tongue:
We always think about it, and then realize there are much better motors that are much easier to use. The power pins on the front require some really interesting configurations to get working. In addition, there are no COTS gearboxes that work with them.
I have not seen this motor used on any robot. I like the motor and am trying to find a good use for it.
A gear box for this motor maybe a good project for some team.
Why would a team waste time finding a way to gear down an 18W motor when there are a plethora of better options available? There are equally compact motors that interface much more cleanly and provide much more power. Further still, if you have a low power, low speed application, the window motor already provides an option without additional external gearing.
I see no reason to use the throttle motor, personally.
Didn’t 1640 use it for doing speed feedback on their shooter some year too?
Yes, 1640 did use it as a tachometer for the ball shooter. That year our programmers were stretched on other things and there was not time for them to get up to speed on quadrature and PIDS. So we attached the throttle motor to the shaft and ran it in to a rc filter. They had an analog voltage from o to 8 volts. What the programming team did from there I don’t remember. It worked. Since then the programming team has learned to deal with encoders.
4678 used one this year with 3D printed gears and gearbox. If I remember correctly they managed to print a gear that matches the pinion permanently attached to the motor. Maybe one of their members could chime in and provide more info.
We had worked out a way to couple it to an existing PG gearbox from AndyMark to use as a steering motor for a swerve drive. We prototyped the coupler and knew that would work, but we never got around to building it into a swerve drive and testing that part out. Our driver for that was the fact that we could use 4 of them and had no place else we would want to use them - if they would work there, it would be great. Of course, just as we were about to start testing it, FIRST started allowing more and more motors… So, that project was shelved, as there are better and easier motors to use for that now that we don’t have to worry about quantity. Of course, that could all change again…
We have bags full of them that we rarely if ever use. The only occasion I can think of when we used one was in 2013 to pull a pin on a spring-loaded flap that was too tall to start the match open so we pulled the pin in auton and it stayed open for the rest of the match. When we did that, we used it with a gearbox like the one shown in the picture below.
http://cdn.firstchoicebyandymark.com/content/images/thumbs/0000537_motor-and-harness-fc16-059_125.jpeg
So it is the power source on the window motor ?
The window motor is a different (but very similar) motor.
Hi I am a member of team 4613 Barker Redbacks, we have designed a low cost, low part count gearbox which gives the motor a 7.5:1 gear reduction, with a ½ hex output shaft. Our team has the capacity to manufacture these gearboxes in-house and we have partnered with a local sponsor. We are going to donate 40 of these gearbox kits to rookie teams in countries where it can be difficult to get parts like Australia, Brazil, Turkey and China among others. We will also spread the project to the FRC community by encouraging teams who have access to similar machining resources and distribute the gearboxes to teams in their area.
We have been in contact with Frank and he has confirmed that the throttle motor will be legal and sent out in the KOP once again in 2016(but with the FirstChoice release, we already knew this)
We have already made several systems utilising the gearbox we have designed, including a Polycord intake.
More information about the project will soon be on our website: www.team4613.org
I want to see what you did with the throttle motor.
4613 you were a great alliance captain on Curie.
Thanks from team 4061.
I remember seeing them on 2512’s robot in 2013. I think they used them on the fly wheels that kicked the Frisbee from their ground intake to their hopper.
This is pretty cool.
We had only thought of using them as speed encoders - similar to 1640. nice that free speed is about equal to a CIM.
If these work and it provides a use that teams can leverage, I am sure that all the throttle motors that anyone would want are available from the team community - for the cost of shipping. - nice re-use / recycle per the original intent I am sure.
Though it remains a low power motor and typically the transmissions are the cost driver not the motor…
(and 10X throttle motor power equals 1X AM-9015 motor power…)
Change is happening! - only throttle motors allowed! 30 throttle motor drivetrains!
The throttle motor gearbox has been designed to be simple to integrate into robot designs, the gearbox shaft smoothly slides through the 1/2 inch hex hole in the gear assembly. This enables teams to use any length gearbox shaft they like, without having to purchase expensive couplers. The gearbox will be sent out with bushings, and it will be simple for teams to replace these with 1/2 hex flanged bearings if they desire.
Images of the prototype throttle motor gearbox design:
How are you dealing with the motor leads being inside the gearbox? I couldn’t see any wires inside the gearbox to power the motor. Maybe I’m missing something.
Due to the gearbox design, there are many possibilities on how to power the motor. We have found spade connectors to be the most effective method of supplying power. These fit through the holes on the front of the gearbox, but the pins can also be bent at 90 degrees to supply power from the sides. Soldering wire directly onto the power pins works great too.
