I have installed the Thunder cRio tools to permit c++ programming on a cRio. I can get the .out output file for the example to be generated. However, when I try to “run as” “cRio C++ deploy” I only see an option for a local c++ application execution. Anyone have ideas?
Thanks,
Ken
I know that LabVIEW support for cRIO has been removed this year, perhaps it has been removed for you too.
I’ve seen that a few times… for me I’ve been lucky to recover by closing eclipse and opening it again… I’ve had that happen 5 times these past 2 days… each time I do this solution it has worked.
