Timed Robot Stateful Autonomous
Hello,
I noticed that @auscompgeek updated the Stateful Autonomous example (Thank you for that). I am trying it out, but am running into some errors.
I cannot call drive code. When I try, I get
  File "C:\Users\l*\Documents\Robotics\RobotPy\examples\stateful-autonomous\autonomous\drive_backwards.py", line 16, in drive_wait
    self.drive.tankDrive(0, 0)
'DriveBackwards' [or DriveForwards] object has no attribute 'drive'
I am using the examples as is. I tried adding the following as suggested in the tutorial… from robotpy_ext.autonomous.selector_tests import *
…but that fails. with
Traceback (most recent call last):
  File "robot.py", line 7, in <module>
  File "C:\Users\*\AppData\Local\Programs\Python\Python38\lib\site-packages\robotpy_ext\autonomous\selector_tests.py", line 6, in <module>
    _gsms = pyfrc.config.config_obj["pyfrc"]["game_specific_messages"]
KeyError: 'pyfrc'
I am wondering what I am missing (I am using the simulator).
Thank you.
~Mr. R^2
The tests shouldn’t be added. Where’s the tutorial you found? Needs to be updated…
Also, make sure you have the latest version of robotpy-wpilib-utilities installed (2020.1.5).
Thank you for your help. I figured out my error. Before I had the correct version of robotpy-wpilib-utilities installed, I had tried changing it to match the tutorial.
In doing so, I had changed the following line…
self.automodes = AutonomousModeSelector("autonomous", self.components)
to be…
self.automodes = AutonomousModeSelector("autonomous")
So, after updating the library and getting it to build, no components were passed during auto.
Doh.
