Posted by Brad Pflum, Coach on team #192, Gunn Robotics Team, from Gunn High School and Nasa Ames, Sun Microsystems.
Posted on 2/28/99 11:27 PM MST
In Reply to: Re: tipping robots posted by jason on 2/27/99 11:15 PM MST:
My name is Brad Pflum, I’m a senior at Gunn High school, co-captain of and Coach of the Gunn Robotics Team #192. In the first round of the semi-finals my alliance was disqualified for “intentionally tipping” the Bay Bomber team #252. As with any controversy, there are two (or more) sides to the story. Here is mine.
Below is Jason’s version. The robot he is talking about is G-Force: my team. I have refuted or agreed with each statement:
: Once, one team was on the puck and controlled it. We were unable to
False. About a minute into the match G-Force was pushed into a corner by bay bombers ally. We were NOT on the puck, nor did we control it. For most of the match we were being pinned against the driver station. About 45 seconds from the end bay bomber raced to the puck and helped pin us. We were spinning our front roller trying to get on the puck but the motors didn’t have the power to lift the robot with two others pushing it into the wall. Our robot uses a truncated wheel in the front to get the front end on the puck and ramps on the underside to drag the back up. It is weighted such that the arm has to be out in front to get on the puck. If the arm is not out in front the weight is too far back and we can’t drag the ■■■ end up. In practice we found that if we juggle the arm up and down it sometime helps get the back up, so for the last minute or so of the match you can see G-Force struggling to jerk and pull itself onto the puck.
: latch onto the pole, so decided to back away from the puck and raise our
: floppies. The robot on the puck waited until we extended, then moved
False. In the last couple of second the bay bomber continued to pin us against the wall. Our ally, the crusher, grabbed onto a pole, raised it’s floppies (it had time to collect 8 because the two opposing robots were pinning G-Force), and elevated. With time running out, bay bomber started to raise it’s basket - they were still driving into the puck at full force. Our arm was out and bay bomber drove into it. That moved our arm a bit and the gyro on the arm sensed it - our (very cool) control system is programed to apply power to the arm if it is falling, and when the bomber drove into the arm the arm wanted to get back to where it was, so the motors drove up and hit the bomber but the lag in the sensors and the control box made the arm start occilating. It hit the bomber on an upswing and since they have a short wheelbase they started rocking. Their driver was still gunning the motors full forward and when the robot rocked back the base jerked forward. Their cg was very high with their floppies up and the tipped farther backwards and their base drove right out from under them. Bay bomber’s ally was, at this time ramming into the crusher and with the pinning action of bay bomber now removed, G-Force jumped up onto the puck.
: their arms under our basket, and intentionally tipped us over with 3
: seconds left in the match (in a slow motion moment of agony, I don’t
: think our robot actually thumped to the floor until well after the match
: had ended.) They were disqualified by the judges for unsportsmanlike
: conduct. The reasoning was this:
: every robot had established their position, we had backed off and
: were not engaging them, we were not in a space on the field or
: controlling anything they would want, and there was absolutely no
You were clearly still engaging G-Force and the puck. The judges’ reasoning was that we were already on the puck. That’s untrue. I was right there starring at the robots and screaming at the top of my lungs “get on the puck!” We just wanted on that puck - if you hadnt been pinning us you wouldn’t have gotten knocked over.
: threat to them or their position. So with the above conditions, it was
: clear that there was ONLY ONE intention with their action - to tip us.
On a more personal note, Jason, as a friend, I hope you don’t belive that. I’ve never wished anything but the best for you’re team. I am so incredibly proud of what your team acomplished, and I would never want to take that from you. Tipping your robot was irrelivant, getting on the puck was our mission. That was our strategy - we control the puck and occupy the other robots while crusher raced around and got floppies and grabbed a pole that we would guard. Tipping you would serve no function anyway. Both our robots were on the puck and crusher had 8 flopping at 8 feet. That’s 216 points. Even if you had all 10 floppies at 8 feet (you didn’t, you had 7) that’s 7*3 times 2 for the puck on our side of the field = 60 points. We had already won. In retrospect, we actually didn’t need to be on the puck ourselves, but our strategy and one goal was to get on the damn puck. It was just luck that there was an open pole for crusher to jump on. We didn’t want to fail.
: In the next match, that very robot which was disqualified against us,
: was tipped over itself. It was tipped about 25 seconds into the match
: They key was that we were trying to defend the puck and clearly had not
: made any attempt to actually tip them on purpose (I hope they know that)
That was a clean hit. Totally legit. I doubt you did it on purpose, but it doesn’t matter anyway. Good shot, but it won’t happen again
: their way to answer any questions we had and/or help us. Our students
: look up to and admire their team (they have actually been the model I
: have used for the past 2 months as to what level our students should try
: to reach within a year or so)
This is what made it all better. When you talked to me at the end of the day I was really touched. I’m not bitter or upset at all with the disqualification. I know, in my heart, that it was unintentional. I do feel bad for The Crusher team, they picked us as an ally and I wish things they hadnt been hurt by a bad referee call.
Last, and possible most importantly: I’m not making this up. I read this thread in the morning and was going to reply but I decided to wait untill I was sure. I watched a video of the match in slow-mo about 6 million times and am confident in my claims. That’s right, I have video to back this all up. We’re working on getting it the tape on a computer so I can make our footage viewable over the web. Our camera angle was apparently much better then NASA’s, there is really no question - the video can’t lie. I’ll get that video up ASAP (with luck sometime this week)
I can be reached by e-mail, but I’ll be busy with the robot till Wednesday when I have to start making up 7 weeks worth of homework
