Hi guys we have a Intel Compute Stick. It is powered by micro usb and uses 5V 2A and I was just wondering how I can power it legally on our robot
Wire it to the VRM. This year the robot radio is 12 V so you have the 5 V 2A connectors free.
We are using an Intel Compute Stick this year too. The VRM 5v 2A should work fine, but for an even easier solution, we just plugged a short USB to micro USB phone charging cable right into one of the RoboRio’s USB ports. It powers the Intel stick just fine.
I didn’t realize that this was this simple.
Derp
Are you guys using the VRM 5v 2A to power a usb hub for the compute stick
All you need to do is strip a USB cable and connect + and - into the 5V 2A output on the VRM. Using a USB hub might work, although you probably don’t need to do that.
This is an appropriate method.
Just curious, what are people using the ICS for? is this in place of a raspberry Pi for vision processing?
I’m pretty sure that is what it is most useful for. A compute stick is significantly more powerful than the Pi in a smaller form factor.
You got it. The intel stick we bought on Amazon shipped with Windows 10. We are using RoboRealm, which is included in the kit of parts, to process the images from an axis camera. RoboRealm has nodes to communicate with the RoboRio by using the network tables. It also supports multiple scripting languages to automate some of the process.
