Having competed with your team and 7225, you are both excellent vault bots. At both events you both shined and stood out. I am interested to see how the game will change at MSC… I do expect to see it evolve drastically when the best in the state face off on the scale and the strategy on the rest of the field determines W/L.
For the districts, I’ve calculated district-wide Vault Power Rankings (like OPR, but only calculating the vault points). It should be relatively good at predicting since this is a linear scoring task.
Chesapeake:
5945 21.22742336
1413 18.77723409
1629 17.64208841
1731 17.09521513
6194 16.64367674
Michigan:
7225 27.83268186
7056 27.00487749
7174 23.14275656
5224 22.88477203
7211 22.39694211
Israel:
2679 20.68897904
5654 18.01022653
5614 16.90288798
1574 15.7964347
5987 14.44535014
Mid-Atlantic:
5181 23.64834084
747 19.37395238
2016 18.84210421
25 18.76350421
222 17.75933748
North Carolina:
6334 19.11494574
2655 18.71965842
2059 18.61324425
6003 17.91449639
4795 17.76443225
New England:
5846 27.67398422
4557 23.73846169
5563 22.60441371
3146 20.54635267
6933 20.41055885
Ontario:
5036 21.80257912
4903 21.27971082
33 18.63922411
6878 18.43197774
1241 18.22044473
Peachtree:
4941 27.45596797
4240 18.75442872
829 18.38099144
4730 16.94266878
6829 16.91668185
Pacific Northwest:
4450 22.7802899
6343 19.22929941
2046 17.95079288
2910 16.58466148
5085 16.27714052
These are only the top 5 for each district. If you want to see your team’s specific ranking, I’d be happy to look it up for you, as well
Indiana is people too…
Ah yes, I knew I was missing one of the districts
. Sorry 'bout that.
Indiana:
3487 19.57791382
226 18.02347933
2171 17.12049655
5484 16.97986064
3936 16.88612893
Note: this will include teams that aren’t necessarily in that district but played in that district (e.g. 226).
6334 is from the CHS district but played at the NC Pitt County event
Edited my post above to make that note.
While they also have other capabilities, 3284 from Missouri is an amazing vault-bot. Their over the shoulder arm design lets them clear the pile very quickly without having to turn around, and they can take cubes without making a mess of the stack. Their stats may not show it because in some matches they spent a fair amount of time trying to work the scale, with somewhat less success.
I think 3750 could fit in somewhere on the list!
We did not do vault very much, choosing to always maintain ownership of the scale but when we did these were the outcomes!
Sometimes getting as many as 3 in 10 seconds.
The key word from my post was “Switch/Vault dedicated”. Y’all are much too good at the Scale to qualify
Of course I’m sure I missed many other fantastic MN teams from my short list. As a region MN has grown so much this year and we have so many teams that have taken a giant step forward. It won’t be long before we can get into arguments with California and Ontario about why we’re better :rolleyes:
1011 is the best vault bot in Arizona. The fact that they can do all their vault duties and still put a ton of cubes on either of the switches every match makes that pretty clear.
6502 actually does the same intake actuation as you do when intaking cubes, but the way they release is actually really unique, as they let go of the cube for a second by opening their arms and then hammer it with their pistons (this is why they named their robot Dropkick). You can see in action in this video: https://youtu.be/DWvzIKzL2CM.
For New England I’d like to put my vote in for 4557 as the best vault bot. Their vault cycles are incredibly quick and consistent and once they’re done with that (sometimes within the first 45 seconds of a match) they can maintain their switch or go take their opponents. Definitely a very smart and up and coming team to look out for.
While they usually spend their time doing other things I absolutely love 610’s vault abilities. They use their shooter to slide the cube across the ground and into the the vault with ease. Combined with some great driving, they make it look effortless.
I’m going to vote for Team 1836 for Southern California. I watches 2 of their regionals and they were insanely quick to the vault (all 9 in 35 seconds or so??) and great at the switch too.
For my CHS district, I will vote Team 888, we picked them at the Southern Maryland district for their quickness with the vault and solid climbing ability
Here is a video in which you can clearly see our exchange mech: https://www.youtube.com/watch?v=qLyt_y6EtJw
Notice how the cube goes all the way through the exchange. There is no need to use the rollers which actually speeds up the vault time considerably as the human player doesn’t have to come back and kick the rollers.
This is cool. Might have to incorporate a puncher into an offseason iteration. Are the solenoids anything special like the McMaster high flow model, or are they typical?
There are four cylinders total, each 3/4" bore 8" stroke. Each one is plumbed to a NITRA single solenoid valve (0.78cv, from Automation Direct, looks identical to bimba high flow ones) and each valve has its own dedicated post-reg 60psi tank right before it. For switch/vault we only use one of the four cylinders.
Originally when we were only a switch/vault bot, we just had two 5.5" (iirc) 3/4" bore cylinders and that worked fine too.
Edit: we also automated the whole clamping/lifting process with a Sharp IR tucked underneath the shooter
hey that 5499 team is pretty good too
Love your machine. It’s definitely one that struck me as a “why didn’t we build that robot” type design when I first saw it. We intended on being a scale robot, but called the audible in week 5.5. In the offseason we are going to remount our elevator (https://youtu.be/I7fvXlelr18) to the chassis we competed with and cut our switch bot down to ~20x24.
