Hello,
We are trying to build a climber using only off the shelf parts and have run into an issue regarding the torque generated by a motor on a PG71 gearbox.
The motor specification (am-0912) reads a stall torque of 60.64 oz-in and a no load RPM of 16000. The assembly of the 9015 and PG71 (am-2084) has a specified stall torque of 6.25 ft-lbf and a No load free speed of 216rpm.
The problem is that these numbers seem to have different ratios.
16000/216 = 74 which is close to the 71:1 gear ratio but 0.316 ft-lbf / 6.25 ft-lbf = 19.8 which is no where near the 71:1. However the power output of the transmission plus motor assembly is stated to be the same at the motor alone, 179 Watts but after using a linear relationship for torque v. rpm I get a maximum power of 47.8W. This is illustrated by the graph here https://www.desmos.com/calculator/w7q7m7wgp6
Am I missing something or are the values reported incorrectly?
Thank you in advance.
