Hello. While brainstorming with my team, I came across what seems to be a contradiction in regards to the dimensions of the tower. If you look in 6.2.4, it states that
The PLATFORM is 44 inches wide by 36 inches deep
I took this to mean that the tower also holds these dimensions for length and width.
However, if you look at the detailed field drawing, specifically GE-10028, it shows that the top of the tower, which extends vertically from the corners of the platform, forms a square.
Furthermore, in 6.2.4 it states that the tunnel is 36 inches wide, which would imply that the bars of the tower are also 36 inches apart. And if you look at the GE-10047 in the detailed field drawings, it shows on the second page that the bump is 36 inches wide, which means that the bars of the tower are 36 inches apart in that direction as well. This supports the drawing of the top of the tower being a square, but it goes against what the manual states, so I am left confused about the true dimensions between the bars. Can anyone help me to clarify this?
Happy that I am not the only one struggling with this.
The PLATFORM is 44 inches wide by 36 inches deep, and is at a height of 20 inches above the floor. A 36-inch wide by 18-inch tall TUNNEL under the PLATFORM, providing a passageway between the MIDFIELD and the adjacent end ZONES.
I would have assumed that the 36" of the platform would coincide with the side of the tunnel that is equally 36". However I am confused as to whether or not this refers to the front and back or the left or right of the platform.
I would also have assumed that when describing the ‘depth’ of the platform it would be the right and left of the platform, but from the above quote, this would be wrong…
Along with Kpchem’s find in the game field docs, I am really confused about the tower dimensions as well as the orientation of the entire tower.
For now, I am also willing to believe that the 44" was a mistake, and that it’s really 36"x36".
Perhaps the 44" refers to little “wings” that extend the platform onto the top of the bumps? the tower itself can still be 36" square and centered on top of a 44" wide platform.
I’m still downloading all the docs, and haven’t gotten to that one yet.
While we’re talking about this, does anyone know the bottom dimensions of the bump? I figured it was the same size as the width of the tower, since they seem to match up in the docs. But anyone have a more solid idea? In the user manual I believe it just mentions the height is 12" and the top of the bump is also 12".
Another thing…
If you will look carefully at the drawings of the tunnel you will see that the material it is built from is wide (looks like a wood or w/e…), and the INNER dimensions of the tunnel is 36" wide (According to the manual) which means the outer width has to be larger, which is also the platform width.
so lets say the width of the material the tunnel is built from (Or the total width) is 4" then it is 36"(Inner width) + (4"(Material width) * 2) with comes to the total of 44" which is the platform width as written in the manual.
