TrackerDemoProject
Hello,
I was wanting to try to use the trackers on a mock up robot for this year and when ever i try to look at the Project(click on the link to it in netbeans). It always says "Message
                    Project:
                    C:\Users\Developer\Demos\CodeSamples\TrackerDemoProject not found!
Any ideas i cant seem to open any of the Sample Projects.
The tracker demo project is for the camera
The “Line Tracker Project” is for the line trackers
line tracker only has one class:
/* Copyright © FIRST 2010. All Rights Reserved. /
Open Source Software - may be modified and shared by FRC teams. The code /
must be accompanied by the FIRST BSD license file in the root directory of /
the project. /
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
  • Sample line tracking class for FIRST 2011 Competition
  • Jumpers on driver station digital I/O pins select the operating mode:
  • The Driver Station digital input 1 select whether the code tracks the straight
  • line or the forked line. Driver station digital input 2 selects whether the
  • code takes the left or right fork. You can set these inputs using jumpers on
  • the USB I/O module or in the driver station I/O Configuration pane (if there
  • is no Digital I/O module installed.
  • Since there is the fork to contend with, the code tracks the edge of the line
  • using a technique similar to that used with a single-sensor Lego robot.
  • This code worked on a simple bot built from the 2011 kit chassis and weighted
  • to behave similarly to complete robot complete with scoring mechanisms. Your
  • own robot will likely be geared differently, the CG will be different, the
  • wheels may be different - so expect to tune the program for your own robot
  • configuration. The two places to do tuning are:
  • defaultSteeringGain - this is the amount of turning correction applied
  • forkProfile & straightProfile - these are power profiles applied at various
  • times (one power setting / second of travel) as the robot moves towards
  • the wall.
  • In addition: this program uses dead reckoning - that is it drives at various
  • power settings so it will slow down and stop at the end of the line. This is
  • highly dependent on robot weight, wheel choice, and battery voltage. It will
  • behave differently on a fully charged vs. partially charged battery.
  • To overcome these limitations, you should investigate the use of feedback to
  • have power/wheel independent control of the program. Examples of feedback
  • include using wheel encoders to measure the distance traveled or some kind of
  • rangefinder to determine the distance to the wall. With these sensors installed
  • your program can know precisely how far from the wall it is, and set the speeds
  • accordingly.
public class LineTracker extends SimpleRobot {
RobotDrive drive; // robot drive base object
DigitalInput left; // digital inputs for line tracking sensors
DigitalInput middle;
DigitalInput right;
DriverStation ds; // driver station object for getting selections
double defaultSteeringGain = 0.65; // the default value for the steering gain
public LineTracker() {
    // create the robot drive and correct for the wheel direction. Our robot
    // was geared such that the motor speeds needed to be inverted for
    // positive speeds to go forward. You may not need these.
    drive = new RobotDrive(1, 2);
    drive.setInvertedMotor(RobotDrive.MotorType.kRearLeft, true);
    drive.setInvertedMotor(RobotDrive.MotorType.kFrontLeft, true);
    drive.setInvertedMotor(RobotDrive.MotorType.kFrontRight, true);
    drive.setInvertedMotor(RobotDrive.MotorType.kRearRight, true);
    // set the MotorSafety expiration timer
    drive.setExpiration(15);
    // create the digital input objects to read from the sensors
    left = new DigitalInput(1);
    middle = new DigitalInput(2);
    right = new DigitalInput(3);
    // get the driver station instance to read the digital I/O pins
    ds = DriverStation.getInstance();
 * This function is called once each time the robot enters autonomous mode.
public void autonomous() {
    int binaryValue; // a single binary value of the three line tracking
                    // sensors
    int previousValue = 0; // the binary value from the previous loop
    double steeringGain; // the amount of steering correction to apply
    // the power profiles for the straight and forked robot path. They are
    // different to let the robot drive more slowly as the robot approaches
    // the fork on the forked line case.
    double forkProfile] = {0.70, 0.70, 0.55, 0.60, 0.60, 0.50, 0.40, 0.00};
    double straightProfile] = {0.7, 0.7, 0.6, 0.6, 0.35, 0.35, 0.35, 0.0};
    double powerProfile];   // the selected power profile
    // set the straightLine and left-right variables depending on chosen path
    boolean straightLine = ds.getDigitalIn(1);
    powerProfile = (straightLine) ? straightProfile : forkProfile;
    double stopTime = (straightLine) ? 2.0 : 4.0; // when the robot should look for end
    boolean goLeft = !ds.getDigitalIn(2) && !straightLine;
    System.out.println("StraightLine: " + straightLine);
    System.out.println("GoingLeft: " + goLeft);
    boolean atCross = false; // if robot has arrived at end
    // time the path over the line
    Timer timer = new Timer();
    timer.start();
    timer.reset();
    int oldTimeInSeconds = -1;
    double time;
    double speed, turn;
    // loop until robot reaches "T" at end or 8 seconds has past
    while ((time = timer.get()) < 8.0 && !atCross) {
        int timeInSeconds = (int) time;
        // read the sensors
        int leftValue = left.get() ? 1 : 0;
        int middleValue = middle.get() ? 1 : 0;
        int rightValue = right.get() ? 1 : 0;
        // compute the single value from the 3 sensors. Notice that the bits
        // for the outside sensors are flipped depending on left or right
        // fork. Also the sign of the steering direction is different for left/right.
        if (goLeft) {
            binaryValue = leftValue * 4 + middleValue * 2 + rightValue;
            steeringGain = -defaultSteeringGain;
        } else {
            binaryValue = rightValue * 4 + middleValue * 2 + leftValue;
            steeringGain = defaultSteeringGain;
        // get the default speed and turn rate at this time
        speed = powerProfile[timeInSeconds];
        turn = 0;
        // different cases for different line tracking sensor readings
        switch (binaryValue) {
            case 1:  // on line edge
                turn = 0;
                break;
            case 7:  // all sensors on (maybe at cross)
                if (time > stopTime) {
                    atCross = true;
                    speed = 0;
                break;
            case 0:  // all sensors off
                if (previousValue == 0 || previousValue == 1) {
                    turn = steeringGain;
                } else {
                    turn = -steeringGain;
                break;
            default:  // all other cases
        // print current status for debugging
        if (binaryValue != previousValue) {
            System.out.println("Time: " + time + " Sensor: " + binaryValue + " speed: " + speed + " turn: " + turn + " atCross: " + atCross);
        // set the robot speed and direction
        drive.arcadeDrive(speed, turn);
        if (binaryValue != 0) {
            previousValue = binaryValue;
        oldTimeInSeconds = timeInSeconds;
        Timer.delay(0.01);
    // Done with loop - stop the robot. Robot ought to be at the end of the line
    drive.arcadeDrive(0, 0);
 * This function is called once each time the robot enters operator control.
public void operatorControl() {
    // supply your own teleop code here
Where by chance did you find this template?
within netbeans
new project
samples
frcJava
note that it is NOT in project->frc java
you have to go into samples
