Anyone have any luck finding the elusive transmission manual?
Rich
Rich
This is last years - did I see that it’s the same as this year’s?
The new one should be on IFI’s website. I was requested to update the manual in December. It is very similar to the 2005 manual, but the “2005” was changed to “2006” and the standard transmission from 2005 is now called the 2 motor transmission. The manual always had the instructions for single motor, 2 motor, and arm configuration as it does this year.
If you can’t get to the 2006 manual, the 2005 manual is fine to use. It has all the same information as the 2006 manual.
The 2006 Transmission Manual can be found on this page:
http://www.ifirobotics.com/kitbot.shtml
It is linked to directly off the front page of:
Here is a direct link to the PDF:
http://www.ifirobotics.com/docs/2006-first-transmission-manual-rev-d.pdf
Thanks to Paul Copioli for updating this document.
