Back in 2000, Woburn’s Blizzard 1 had just such a control. But it wasn’t included to surprise people–there was a bit more pragmatism involved! As it happened, that robot had front-wheel-drive (old Johnson drills) and rear casters, and because the weight distribution was very biased toward the rear, the robot had an annoying tendency to over-rotate when trying to manoeuvre. That button was in there so that full speed could be achieved if necessary (and usually with a fixed rear wheel deployed, raising the robot off of its casters), but under normal conditions, the robot wouldn’t be so difficult to control. I’m not so sure it was of much actual use, though, since that robot was by far the worst-driving of any of the Woburn family (of those that I’ve taken for a spin, at least–that’s the last six, plus one of the ancient Canada FIRST robots). It certainly wasn’t an efficient or elegant solution, as sanddrag pointed out.
This sort of solution is only useful if you don’t care about the power output (in 2000, we knew we had enough power to drive around at half-throttle), or conversely, don’t care about the current and efficiency (we should have cared–we threw 30 A breakers on some occasions, that year, and were limited to a 60 A main fuse, not a 120 A main breaker). You’re effectively decreasing the voltage of the motors–for instance, by half–which just doubles the current needed to sustain a certain power level. This is why it is fundamentally crazy to control something like a (DC permanent magnet brush) motor at low throttle settings (i.e. the Victor’s output voltage is a fraction of the motor’s rated quantity); you’re just going to force the current way up, and the efficiency way down. Low efficiency just means heat losses, and to compound the problem, the internal fans don’t work well at low speed.
So what’s the right way? Shift gears. You’ll have two speed ranges that allow the driver to avoid overstressing the motors by running them too slowly.
Of course, sanddrag already knows all of this, so I suppose that this is for everyone else out there…
