Any teams with triple NEO drivetrain browning out? Just curious because someone on discord told me it might happen but I haven’t heard of this issue before.
Not if you run current limits on the Spark Max
Even testing in our shop without applying current limits we were having a hard time trying to brown out in 18fps high gear on 6 NEOs. 4awg battery cable and a 13v battery may play into that a bit.
We have done triple CIM drivetrains with brownouts, but I think the NEOs are low enough current to avoid these problems with the same if not better outputs but you need to put current limiters on those neos
The motors should have little to do with that. What is more important will be your gearing, wheel configuration, software setup, and battery health.
