My team is using a Jetson TX1 for CV this year, and I am getting to the part where I need to communicate. Network tables seemed like an easy solution, but I’m having problems installing pynetworktables.
Tne problem seems to be having mismatched python versions, as my CV is configured for 2.7, but the networktables only installs for 3.5, even if I am using regular pip instead of pip3. Is there any way of getting it working for python 2.7, or should I start looking at serial?
An alternative way to execute pip is via ‘python -m pip’. Presumably if you execute it with the same interpreter then it will install to the correct location for that interpreter.
