This year we’re trying to use an ADXRS453 gyro on our robot. (With this eval board.) Yesterday we wired it up and managed to communicate with using the WPILib SPI class. We simply read the sensor data every time TeleopPeriodic was called, and integrated the results to get a measure of our heading. This worked extremely well, as in, the heading would not change at all while the gyro was sitting still, and changed as we would expect it to when we rotated it.
Then we go to work with it today, without changing the program, and it drifts like crazy. (Like, a degree every couple of seconds.) We wrote code to try and compensate for it, by sampling the rate for a couple seconds while it’s still, and the values still oscillate and drift while the gyro is sitting still.
In another thread, members of several teams said they had used this gyro with success. Any idea what’s going on? Any wisdom you can share about how to work with it?
Thank you for sharing the code for the gyro. A couple of comments:
You used a Task and Timers rather than a notifier. Seems like a notifier could make the code easier, but there are also two timers which indeed complicate a bit. Are two timers needed? I’d have to read closer to work it out.
The floating point values are floats instead of doubles. Any particular reason? I’m used to thinking of doubles as being just fine for most uses. WPI Lib seems to use doubles everywhere.
The float values are being updated from a task and read from the robot loop. I think a mutex is needed to protect the values being read. Keep in mind that this year, we really do have multiple processors which means we should pay attention to atomic operations. I don’t think a double or float is atomic.
This should be great for us to get going with the gyros.
I’ll be happy to contribute to any changes we make.
I did not change the original code all that much. The changes you recommend make sense. One could use a single timer for both the calibration and update functions. I’ve not used a WPI notifier yet. Is it a wrapper for a counting semaphore? The gyro started working right and I wanted to get it to the students to work on their autonomous behaviours.
I did not think the precision was necessary. One can only “point” the robot with a certain amount of accuracy anyways. Doubles will work.
Floats are atomic as they are word-sized on a 32-bit machine. But a more portable implementation would protect the data - good idea.
