Here are the error messages I keep getting
Could not run phased build action using connection to Gradle distribution ‘https://services.gradle.org/distributions/gradle-7.3.3-bin.zip’.
org.gradle.api.ProjectConfigurationException: A problem occurred configuring root project ‘TimedFullRobot’.
Could not resolve all files for configuration ‘:classpath’.
Could not resolve edu.wpi.first:native-utils:2022.7.1.
Required by:
project : > edu.wpi.first.GradleRIO:edu.wpi.first.GradleRIO.gradle.plugin:2022.2.1 > edu.wpi.first:GradleRIO:2022.2.1
No matching variant of edu.wpi.first:native-utils:2022.7.1 was found. The consumer was configured to find a runtime of a library compatible with Java 8, packaged as a jar, and its dependencies declared externally, as well as attribute ‘org.gradle.plugin.api-version’ with value ‘7.3.3’ but:
Variant ‘apiElements’ capability edu.wpi.first:native-utils:2022.7.1 declares a library, packaged as a jar, and its dependencies declared externally:
Incompatible because this component declares an API of a component compatible with Java 11 and the consumer needed a runtime of a component compatible with Java 8
Other compatible attribute:
Doesn’t say anything about org.gradle.plugin.api-version (required ‘7.3.3’)
Variant ‘runtimeElements’ capability edu.wpi.first:native-utils:2022.7.1 declares a runtime of a library, packaged as a jar, and its dependencies declared externally:
Incompatible because this component declares a component compatible with Java 11 and the consumer needed a component compatible with Java 8
How did you install VS Code? I’m guessing that you didn’t use the WPILib installer. The error message says it’s running with Java 8, but it needs to be run with Java 11.
