Trouble With SparkMax Idle Mode 2025
Hello everyone! I’ve been coding some old robots recently to learn FRC coding and I’m using the 2025 beta version that uses the SparkMax class. I can’t figure out how to set idle modes through code in java. Most things say to use the setIdleMode method, however I can’t find it. Any help is appreciateed.
REV redid their API for 2025. Check the new config process.
I can’t find an example on how to use this at the moment.
Here’s some relevant discussion on the 2025 beta repository:
This looks like a possible way to set it
SparkMax motor_ = new SparkMax(0, SparkLowLevel.MotorType.kBrushless);
SparkMaxConfig config_ = new SparkMaxConfig();
config_.idleMode(SparkBaseConfig.IdleMode.kBrake);
motor_.configure(config_, SparkBase.ResetMode.kResetSafeParameters, SparkBase.PersistMode.kPersistParameters)
This example use a motor of ID 0 and expects a Brushless motor. Make sure to change this to match your setup. I just picked random values for the Reset and Persist Mode. Look at what Jonah shared above to decide what to use.
FYI: There may be a better way to do this, but I haven’t looked much into the new REV API.
