Trouble with the Pneumatic Control Module
So, we’re having trouble with our PCM. I was wondering what the status light being green, and the comp light is off.
Page twelve is about the LED for the compressor… aka if the LED is off the compressor should not be running…
If I’m not mistaken, that means everything is working correctly, the VRM is communicating with the roboRIO, and the compressor is not on. Can you describe what kind of problems you’re having that make you think that the VRM is not working correctly?
when we run the sample code provided by the labview program, the compressor nor the solenoid will activate
That would happen if the compressor switch is not wired in…
That would happen if the robot was not Enabled…
That would happen if the code you intended to run isn’t running…
Perhaps you could describe (or photograph) what you have wired up and how.
