Tune REV Spark Max PID for shooter
If you have a PID loop then it should be able to react any error regardless of the battery voltage. I don’t know if you need to tune your I gain to accommodate the battery voltage.
I agree. The trick is that the F-term and P-term are proportional to battery voltage, so that is the system error that need to be corrected.
Also, no one has mentioned it yet, but keep in mind that if you start with f, and then add p, you can get close, but without an I term, you won’t land exactly at your set point.
That’s actually ok. The I term might cause more problems than it’s worth. I would link to a thread discussing it, but I’m typing on a phone.
Without either an f or an I, your final speed might be nowhere near your set point.
Another method you could use is use bang bang and PID control. Basically, you would have a small zone around your target velocity where you would use PID to control your velocity (maybe around 1000-5000 ticks?). If you are not in that zone to use PID, you would just use bang-bang control, which is essentially just setting your flywheel to 100% speed if under the target velocity and 0% if over the target velocity.
