Turning the swerve module
I’m doing some motor calculations to figure out the torque I need to rotate the bottom part of the swerve module I’m designing, here is my math
160 lbs for robot weight with battery and bumpers
160lbs/4 modules = 40 lbs per module
the colson wheels have a CoF of 1 (this is from the vex website). Times 2 wheels per module is 80 Lbs.
at a distance of 1.5" each wheel should create 120 Lb-In of torque.
If we convert to nm we get about 13.5. I was planning on using a BAG motor and was hoping to have it on a 20 Amp breaker, and also only use one gearbox stage. With this criteria I can achieve a 80:1 gear ratio for the bag. Even at 20 Amps, this only gets 12nm of torque.
I was wondering how other teams handle this problem. The bag can handle it at 20-30 Amps, but then the system uses all our 40-30 amp breakers, I could use a 2 stage gearbox, but this adds considerable cost to the design. Also, I’m not exactly sure about my physics, so if you have any suggestions, or corrections to the physics, I would be grateful for your expertise.
After further thought, I was thinking I could pull it off if I used the banebots wheels. However, I don’t know the CoF for these wheels and don’t know where to find this info.
The PDP has 16 slots, 8 of which are 40 A and 8 of which can be 20 or 30 A. So all 8 of the smaller slots can be 30A, allowing you to run the steering motors on the smaller slots. We run a 550 motor with an about 63:1 gear ratio turning one colson wheel and it is at a pretty solid turn rate. A BAG motor has a lower RPM than a 550 so the gear ratio will be slightly different but it should be able to be done with 2 overall stages such as the one you have right now with 80:1. I’ll see if I can re run the math with our swerve modules and see if theres any difference in how you are calculating it.
We’re running colson wheels, although each module only has one wheel and it is almost centered, on a bag with about an 80:1. In the past we’ve run from 100:1 to 50:1, and we’ve found 80:1 is about a sweet spot.
Thanks for the clarification. I haven’t dealt a lot with the electronics, not my forte. But if the small PDP slots can do 30 I should be fine.
