Two Joysticks
How do program to use two joysticks in LabView
Hi SamRI,
If you’re using the basic framework, here’s one way:
Select the Open VI that already exists. (Along with the constant)
http://img238.imageshack.us/img238/7864/59259657aq2.jpg
Hold Ctrl and click and drag the selection to make a copy of them. Place it right below the other and change the constant to “USB 2” … or whatever port you’re using.
http://img48.imageshack.us/img48/7756/16607562ay4.jpg
Wire it up just like the other one
http://img292.imageshack.us/img292/2559/45010627kh4.jpg
And then lastly (don’t forget this) be sure to close it out. On the other side of the loop select the Close VI and copy it just like you did with the Open VI
http://img107.imageshack.us/img107/7994/95147559xu5.jpg
And then just wire it up
http://img296.imageshack.us/img296/8240/64317627er2.jpg
I hope that answers your question.
Good luck!
  • Austin
Thanks for the help
But We are using the Advanced settings because the Basic Setting didnt work on our bot
