Can we have two pressure regulators? I’ve checked the manual and it doesn’t say no.
Once you’ve regulated below 60 psi working pressure (done with your first regulator), you are allowed to use additional ones downstream of the first if you choose.
That’s usually a good sign.
R75 B says you can have only one primary regulator. You can install as many regulators you want downstream of the primary regulator.
