Two Story Pit Area?
While FIRST will never allow it, it can be fun to dream…
http://www.ncaonline.org/DataProducts/images/Rawlyn212.jpg
This thing is called a Tower Blind and hunters use it to blend in with surroundings and get some nice pre-fab shelter from which to pick helpless animals off with. Tower Blinds are made to be quite portable and are usually pretty small, (I’d say roughly within that 10*10ish area) so that they are easily transported to hunting sites. I haven’t done a whole lot of research but I think they run upwards of $800 to $4,000.
Practically this is about the easiest way to actually get your idea safely into a pit… Oh, and I think scouting should get dibs on that second floor…
Does anyone have pictures of this? I’d be really interested to see something like this.
Also, do you think that anyone would have a problem with a camera on a 15 foot high pole? I don’t know why, but it’d be pretty cool to have at your pit. You could see what’s happening pretty much everywhere.
Hey… FIRST competition pit traffic reports.
And that hunting thing doesn’t seem to be blending in very well. Then again, it’s probably made to be placed in trees.
The point with the hunting blind isn’t the blending in, it’s a preassembled, multi -level, easy to dissasemble, relatively within the the pit dimensions, pretty cheap, structure.
I didn’t pick the best picture, but there are many different brands/varieties, but most fit the above criteria. If you seriously wanted to do something, this is one of the easier ways of going about it.
I found the pic I have, http://www.chiefdelphi.com/media/photos/24597
If you look close you can see someone up there
Let me think about it for one second.
OK, I am done thinking about it.
How about “NO!”.
We are flexible, but not that flexible.
Hmmm. Come to think of it, one of the main reasons people are thinking a two story pit would be cool is because of the comfy space.
So perhaps FIRST could just put this into their site agenda and avoid the saftey hazard of teams trying?
Think the Autodesk Couch area at nats, but at every regional, and bigger there’s just enough room if they move some of the arena chairs around…
I mean regionals are getting to the size where getting comfy seats should become a priority. If they put said comfy sofa area in the stands behind the pits, they’d avoid spectator squaters, meaning a cool hangout place to stratigize and stuff. But where would they get the couches? I can just see the agenda now, “be sure that your team brings a sofa to relax with”.
But seriously, scouts and such work their butts off, is a nice place to relax for a few minutes too much to ask?
Instead of multi-story pits. How about a raised pit? or split-level pit? Surely there isn’t a FIRST rule stating that the pits must be on the ground right?
It would make getting the robot up there a little difficult but given the thoughts being tossed around, I’m sure someone can figure it out.
http://img.photobucket.com/albums/v235/ronald_raygun/raisedpit.jpg
If you take a look at the picture, that cutout is for the robot cart and lifting mechanism. the space between the pit and floor will have no body parts, but instead, they will have buckets full of tools, parts, etc. The front of the pit (and side if you are lucky enough to get a corner) will have cabinets for storage purposes.
I’m not sure I understand why this would supplant the tables and workbenches most teams currently have in their pit. Storage space is already available under them. Do you have other purposes for raising the pit deck?
it would give you an “eye up” on the compition…allowing tall people to see completly arounf them and see where other team members are or other things
A two storied pit area would be cool and interesting but come on it has unsafe written all over it especially if there are intentions for using the second story. :wink:
I’m kind of liking this idea. Certainly not nearly as extravagant as my original idea, but you could have the floor be all hinged panels and the bottom area compartmentalized and you could keep all your stuff below the floor with easy access. It would provide good storage and easy accessibility.
i couldent resist…
heres my version 1
http://i99.photobucket.com/albums/l294/fimmel2006/pitlq.jpg
complete with track lighting
I hate to burst everyone’s bubble
and before someone tells me that the rules can change i will put money on this one NOT changing
Wouldn’t it be better to focus all this attention and energy on making something useful or better for your robot? :rolleyes:
That rule (the bolded part) States that you aren’t allowed to have storage above people’s heads. That is because if something heavy falls, it will hurt the person below it. The rule doesn’t state that you can’t support your workspace above a storage area, only that you can’t put heavy things above your workspace.
However, the aforementioned rule also states that the structure cannot hold people. So that removes most, if not all, possibilities of creating a second tier/story. But if the second level was to be for storage purposes, then as Cody C says, it would not be allowed to be higher than the work area/above people’s heads.
Doesn’t it specifically state the structure cannot support PEOPLE above the WORK AREA. Now if you have supplies under you that technically isn’t the work area.
With that rule being read as you are applying to the shorter split level design, it states that no structure can hold storage or people above the work area, if we take that to mean floor then tables would be against the rules. I am pretty sure that the rule is helping to enforce the no dual level pits not isnt going to create a problem with the last 2 pit designs displayed. but when all else fails come january you can always ask in the Q&A rules section.
A sub-floor, Interesting idea. This would be a nice compromise, other than giving teams an extra 5 feet. The problem is the fact that not all teams engineer things to the same quality. FIRST is just trying to cover themselves from legalities. Sadly, most regionals already take on 1-2 lawsuits per regional, which is a sad statistic for gracious professionalism.
Originally Posted by FIRST Rulebook Section 7
7.7.4 NEW: Team Stations
These designated spaces help organize team placement and help team members, judges, and visitors find
teams easily. Please keep your numbers visible and aligned. They are set up to be as equal as possible.
Each team’s pit station will have a table and power outlet.
For safety and because of insurance regulations, teams cannot build any structure that supports people or
items for storage above the work area in their pit space.
No structures should be higher than 10 feet above
the floor and must safely support any signs or displays mounted to the structure. FIRST will require the
removal of any pit structure that is deemed unsafe by event management personnel and local committee
members.
As mentioned by numerous people before me, FIRST does not allow anything go be stored above the work area. FIRST handily did not define the work area, so we can safely assume the work area can be on any plane (i.e. a table and the floor) as long as nothing is above it other than the parts and tools required to do whatever work is needed.
Some of us are familiar with the construction of the Battlebox and other robotic combat arenas. Surely we can figure out some sort of module configuration similar to what you see below.
http://img.photobucket.com/albums/v235/ronald_raygun/318b3982.jpg
Each module is 1.5’ tall and 2’ x 2’. The ones with the translucent flaps on the side(s) are modules meant for the edges/corners. The translucent flaps are the doors for the sides of the modules. The modules that have open sides go in the back and interior. The hole in the top of the module is 2" in diameter and meant for anyone to stick a finger in and remove the entire flap. I decided not to use hinges primarily because the doors could get in the way and they may end up interfering with other modules. The removable floor/door thing would make repairing the module a little bit easier.
Here is what it would probably look like when all assembled together.
http://img.photobucket.com/albums/v235/ronald_raygun/99e6d140.jpg
If I really wanted to be fancy, it’s possible to put walls between the modules so you can set up one 2x2 module section for raw materials, and another 1x2 module section walled off for tools, and a 1x1 module section for buttons, and scouting forms. The possibilities are endless. The walls on the sides are for whatever banners would be put up there. I was thinking of making the entire floor transparent or maybe a little translucent and turning the pit into a disco floor. But that’s just me and my crazy imagination.
EDIT: Look up any manufacturers of portable stages, it’s basically the concept I want to pursue with this pit. It also helps those teams who’s manufacturing capabilities are not top quality.
Any thoughts?
