can you put two visions on the center goal and get two tetras on each of you’re corners? :yikes:
If you can manage to do that in 15 seconds, I don’t see why not.
Just use two robots.
And make sure that they don’t hit each other when capping.
I think a lot of people will have this question, but I haven’t seen a rule stating that you can’t. Just says if you get a tetra on the center goal during auto, you’ll get two bonus tetras… so that would go for each tetra separately, from what I read.
there is no rule that i can find that states that is against the rules so i would hope so even though that would be really hard to do because you have to remember that the center goal is 7feet high and to get a good drop of the tetra u have to lift it about 9.5 to 10 feet high to clear the top of the goal, unless u slide it up the side but in auto that could be alot harder to do then to just lift and drop.
If you can put both on, I dont see why not.
cool
I don’t see why they would give us two vision tetras if we weren’t able to.
that would be sooo hard to do but if you think of the possible points for that it could make a match because if your strategy is to make rows then you could have 4 possible rows started already and just the initial points from that would be 9 just from that one movement. I think the teams that are able to do this in auto mode will some of the highest picked or seeded teams at the comps this year.
