Type of wheel in shooter
What way would you recommend we put our wheels? 2 from the side or 1 on the bottom? What has the most advantage in straight flight path?
I think one on the bottom would usually have a more straight path since if you had ones on the sides, any discrepancies between each of their velocities could cause the ball to exit at an angle.
Teams have made both work. If your plan is to shoot accurately from long distance then you’ll want a goodly amount of backspin. That argues for a single wheel shooter.
