Hi, I’m having some problems with the ucpp project. I’m running arch linux, with wine version 1.3.35 and no programs installed into it except for whatever ucpp did. Here’s what I did:
I downloaded the zip file from https://github.com/nikitakit/ucpp, unzipped it, then moved it to /home/adam I added /home/adam/ucpp/ucpp to my path, installed wine and wine_gecko (using pacman), then went to the directory where my c++ project is. There are three header files, two with constants and one is the header file for main, and main.cpp; and two directories with other classes. I typed:
$ ucpp setup -t 3238
$ ucpp configure
and got an error about bash not recognizing commands in ucpp_gen_makefile.py, so I added
#! /usr/bin/env python2
to the top of both that file and the gen_wpilib_makefile file.
I ran
$ ucpp configure
with no errors, and then I ran
$ make
which outputted the normal things that make does ("building… "), but an error message window popped up and said that nmppc had a serious error and crashed. On the terminal window, the error was:
building 2011-12-19-0_partialImage/Debug/2011-12-19-0_partialImage.o
building 2011-12-19-0/Debug/2011-12-19-0.out
wine: Unhandled page fault on read access to 0x6e795373 at address 0x7bc48b8b (thread 0023), starting debugger...
Unhandled exception: page fault on read access to 0x6e795373 in 32-bit code (0x7bc48b8b).
Register dump:
CS:0073 SS:007b DS:007b ES:007b FS:0033 GS:003b
EIP:7bc48b8b ESP:0067fc10 EBP:0067fc58 EFLAGS:00010202( R- -- I - - - )
EAX:00000f10 EBX:7bcb6ff4 ECX:00000000 EDX:00116c80
ESI:6e795373 EDI:00110014
Stack dump:
0x0067fc10: 00000200 00000370 7bc48891 7bc485ce
0x0067fc20: 00000004 7edebc40 0067fc48 7bc37321
0x0067fc30: 00000f0a 00000f10 0067fc98 00000f10
0x0067fc40: 00110060 7edec620 0067fc68 7bcb6ff4
0x0067fc50: 00110000 00000002 0067fcb8 7bc4923e
0x0067fc60: 00116c80 7ede3ff4 0067fc98 7ed92c53
Backtrace:
=>0 0x7bc48b8b in ntdll (+0x38b8b) (0x0067fc58)
1 0x7bc4923e RtlFreeHeap+0x7d() in ntdll (0x0067fcb8)
2 0x7ed8e926 MSVCRT_free+0x25() in msvcrt (0x0067fcd8)
3 0x00455eba in nmppc (+0x55eb9) (0x0067fcf8)
4 0x0040b5d5 in nmppc (+0xb5d4) (0x0067fd08)
5 0x00409505 in nmppc (+0x9504) (0x0067fd18)
6 0x00409760 in nmppc (+0x975f) (0x0067fd78)
7 0x00402def in nmppc (+0x2dee) (0x0067fde8)
8 0x0040339e in nmppc (+0x339d) (0x0067fe28)
9 0x004011e7 in nmppc (+0x11e6) (0x0067fe60)
10 0x00401238 in nmppc (+0x1237) (0x0067fe70)
11 0x7b859b1c call_process_entry+0xb() in kernel32 (0x0067fe88)
12 0x7b85adaf in kernel32 (+0x4adae) (0x0067fec8)
13 0x7bc74550 call_thread_func_wrapper+0xb() in ntdll (0x0067fed8)
14 0x7bc7735d call_thread_func+0x7c() in ntdll (0x0067ffa8)
15 0x7bc7452e RtlRaiseException+0x21() in ntdll (0x0067ffc8)
16 0x7bc4bc5e call_dll_entry_point+0x33d() in ntdll (0x0067ffe8)
17 0xb76e99bd wine_call_on_stack+0x1c() in libwine.so.1 (0x00000000)
0x7bc48b8b: movl 0x0(%esi),%edx
Modules:
Module Address Debug info Name (16 modules)
PE 400000- 47a000 Export nmppc
ELF 7b800000-7b9c4000 Dwarf kernel32<elf>
\-PE 7b810000-7b9c4000 \ kernel32
ELF 7bc00000-7bcd3000 Dwarf ntdll<elf>
\-PE 7bc10000-7bcd3000 \ ntdll
ELF 7bf00000-7bf04000 Deferred <wine-loader>
ELF 7ed52000-7eded000 Dwarf msvcrt<elf>
\-PE 7ed70000-7eded000 \ msvcrt
ELF 7efb2000-7efbf000 Deferred libnss_files.so.2
ELF 7efbf000-7efe9000 Deferred libm.so.6
ELF b752c000-b7531000 Deferred libdl.so.2
ELF b7531000-b76ae000 Deferred libc.so.6
ELF b76ae000-b76c9000 Deferred libpthread.so.0
ELF b76e0000-b7823000 Dwarf libwine.so.1
ELF b7824000-b7845000 Deferred ld-linux.so.2
ELF b7845000-b7846000 Deferred [vdso].so
Threads:
process tid prio (all id:s are in hex)
0000000e services.exe
0000001e 0
0000001d 0
00000019 0
00000017 0
00000015 0
00000010 0
0000000f 0
00000012 winedevice.exe
00000018 0
00000014 0
00000013 0
0000001a plugplay.exe
0000001f 0
0000001c 0
0000001b 0
00000020 explorer.exe
00000021 0
00000026 licproxy.exe
00000027 0
0000000b (D) Z:\home\adam\.ucpp\gccdist\WindRiver\gnu\3.4.4-vxworks-6.3\x86-win32\bin
mppc.exe
00000023 0 <==
Backtrace:
make: built targets of /home/adam/team3238/2011robotcode/cpp/2011-12-19-0/PPC603gnu
A few seconds later, after the next prompt had showed up, I got another error message:
err:ntdll:RtlDeleteResource Deleting active MRSW lock (0x111f64), expect failure
The first problem shows up only when everything compiles with no errors (it shows up when there are warnings though). It doesn’t show up when everything is already compiled (ie make doesn’t do anything). The second problem appears to show up randomly.
Since I don’t have a cRIO handy, I’m not sure if this is actually affecting the outputted code or the deploy function.
Hopefully I can get an answer to what the problem is or help the developer fix something.
