Unable to format roborio with 4.0 image
Our team is using WPILIB 2022.3.1 and it requires a roborio with a 4.0 image. However , when we are formating the image to the roborio, it breaks at the checking login process. l have turned off my firewall, it doesn’t take effect. Is there any other solution?
If this is the roborio 2, try imaging the SD card instead. When we tried to image it to the new 4.0 image even after we had already done the previous imaging process it didn’t work so we just did the SD card image again.
Ditto
This is roborio 1.0 and l have found that it is a problem of windows 11.
Same problem occurs on Windows 10.
Did you try a different USB cable?
How about Safe Mode (on the Rio)?
