under 2 sec Mini bot
Our minibot climbs the pole in 2.14sec (at least thats what we were told by a comment) and it is built solely from the TETRIX kit’s parts.
i’m pretty sure that with a bit improvement or Weight reduction we will be able to go up in less than 2 sec.
Our minibot’s first test run-
Here’s a 1.8 second run:
http://www.youtube.com/watch?v=NnCfXzmwe6o
And here’s the 1 second deployment:
http://www.youtube.com/watch?v=h2HWZeGKp5I
Very nice minibot and deployment mechanism. Great use of springs. Very simplistic. With the minibot and it’s deployment this year I believe that the designs that are simpler will be more effective. Great work!
:eek: did it?
I would assume some of these minibots don’t have gearboxes.
Or modified gearboxes;)
Cybergnomes have just done it! 1.88 sec! With room for improvement! :yikes:
Nice job! I’m assuming you will modify you’re deployment to 18 inches.
Team 3015 here. We have made a mini robot that went up in 4 seconds or so with the battery on it. I was just wondering if that is considered good or bad?:ahh:
4 seconds as of right now seems a little below average on CD. However, I think that you’ll find that at whatever compitition you go to that 4 seconds will certainly be competitive and you will win your fair share of minibot races.
Good Luck
Im proud to say that we can deploy in .3 seconds, so if anyone wants to loan us a minibot…
Any team that gets a minibot to climb has done well. It isn’t a matter of good or bad, just a question if your design is going to be more or less competitive measured against other minibots. According to many posts on this forum, there are several minibots able to climb in 2 or less seconds and many have indicated times in the 3 second range. If you want to improve your time, consider looking through this and other related threads for some ideas to help your team out. Consider modifying your gear ratios and reducing weight to reduce your climbing time, and keep trying to improve!
Exactly.
Also remember the proof is in the pudding. If you go and your minibot consistently climbs the tower, that makes you a very strong contendor no matter what.
Many folks tend to… “overstate” the potential of their robot/minibot. Wait till you see a couple competitions. After all, the minibot is not part of the allowance and as such you can work on it pretty much anytime to improve it.
This is excellent advice from a very consistent hanging team last year. Just like last year’s bonus, many will attempt, but statistically few will succeed. At an absolute minimum, it is a 10 point endeavor if you consistently succeed. It takes a lot of tube hanging to make up those 10 points.
In fact, it takes at least 3 tubes on the top row (3 in a logo in the middle row works too) to get 10 points. That’s huge.
anyone using omin mini wheel for the minbot
WHY? making a pole-dancing robot?
I’ve been hacking away at that joke all season.
“Presenting Team Fusion’s mini-bot, Miss Candy!”
:stuck_out_tongue:
We just made 3 seconds from start of deployment to triggering. .3 seconds to deploy (plus maybe .1 for the minibot clamp to release), 2.85 seconds for the climb itself.
I do hope that we can regularly deploy though. The robot will probably be able to drive tomorrow and we can do a full test of how difficult it is to align and deploy, but for now anything could happen. We tried to design our robot with deployment in mind though. The camera is mounted on a servo so we can turn it around to align for deployment, and supposedly our deployment tray is able to self-align during deployment as long as the brakes aren’t on.
What about trading minibots? Who has a flexible enough deployment system to handle a variety of minibots? It looks like our tray will be able to deploy anything that has a vertical neck no more than ~3" wide. Have any teams been actively collaborating with others to build compatible minibots?
It’s nice to hear all these claims about how fast you climb and deploy… But I wanna see you at the pole at that ten second mark deploying and be the first one up… You may have the fastest minibot out there… But means nothing if you aren’t at that pole at the second that base lights up…
Getting to that tower will be the hardest thing to do… You have to cover alot of area to get there…
