Unhandled exception instantiating Competition day problems!
I am getting this error thrown from the driver station.
ERROR  1  Unhandled exception instantiating robot edu.wpi.first.hal.PWMJNI edu.wpi.first.hal.util.UncleanStatusException:  Code: -1029. HAL: Resource already allocated  frc.robot.Robot.<init>(Robot.java:31)
Warning at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:234): Robots should not quit, but yours did!
ERROR  1  Could not instantiate robot edu.wpi.first.hal.PWMJNI!  edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:235
it is saying there is a problem with line 31 i do not understand what the problem it. THe error code is being displayed in The FRC Driver station.
My code:
/* Copyright (c) 2017-2018 FIRST. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package frc.robot;
import edu.wpi.first.wpilibj.VictorSP;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import frc.robot.subsystems.DriveSubsystem;
import frc.robot.subsystems.Thearm;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the TimedRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the build.gradle file in the
 * project.
  VictorSP _motorarm = new VictorSP(2);
  Joystick stick = new Joystick(0);
  public static OI m_oi;
  //drive
  public static DriveSubsystem driveSubsystem = new DriveSubsystem();
  Command m_autonomousCommand;
  SendableChooser<Command> m_chooser = new SendableChooser<>();
  public static Thearm m_Thearm = null;
   * This function is run when the robot is first started up and should be
   * used for any initialization code.
  @Override
  public void robotInit() {
    m_Thearm = new Thearm();
    m_oi = new OI();
    // chooser.addOption("My Auto", new MyAutoCommand());
    SmartDashboard.putData("Auto mode", m_chooser);
   * This function is called every robot packet, no matter the mode. Use
   * this for items like diagnostics that you want ran during disabled,
   * autonomous, teleoperated and test.
   * <p>This runs after the mode specific periodic functions, but before
   * LiveWindow and SmartDashboard integrated updating.
  @Override
  public void robotPeriodic() {
   * This function is called once each time the robot enters Disabled mode.
   * You can use it to reset any subsystem information you want to clear when
   * the robot is disabled.
  @Override
  public void disabledInit() {
  @Override
  public void disabledPeriodic() {
    Scheduler.getInstance().run();
   * This autonomous (along with the chooser code above) shows how to select
   * between different autonomous modes using the dashboard. The sendable
   * chooser code works with the Java SmartDashboard. If you prefer the
   * LabVIEW Dashboard, remove all of the chooser code and uncomment the
   * getString code to get the auto name from the text box below the Gyro
   * <p>You can add additional auto modes by adding additional commands to the
   * chooser code above (like the commented example) or additional comparisons
   * to the switch structure below with additional strings & commands.
  @Override
    m_autonomousCommand = m_chooser.getSelected();
     * String autoSelected = SmartDashboard.getString("Auto Selector",
     * "Default"); switch(autoSelected) { case "My Auto": autonomousCommand
     * = new MyAutoCommand(); break; case "Default Auto": default:
     * autonomousCommand = new ExampleCommand(); break; }
    // schedule the autonomous command (example)
    if (m_autonomousCommand != null) {
      m_autonomousCommand.start();
   * This function is called periodically during autonomous.
  @Override
  @Override
  public void teleopInit() {
    // This makes sure that the autonomous stops running when
    // teleop starts running. If you want the autonomous to
    // continue until interrupted by another command, remove
    // this line or comment it out.
      m_autonomousCommand.cancel();
   * This function is called periodically during operator control.
  @Override
    if(stick.getRawButtonPressed(1))
      _motorarm.set(.4);
    } else if (stick.getRawButtonReleased(1)){
      _motorarm.set(0);
   * This function is called periodically during test mode.
  @Override
  public void testPeriodic() {
Without seeing more code or more of the error, I can’t tell you exactly where. Verify every motor controller constructed is on a different port/ID.
robo2020.zip (22 Bytes)
there is my code
If it’s possible to upload to Github, I could take a look. Otherwise, it’ll be a few hours before I could open up the zip.
i got it figured the problem was the port mapping
