After trying to correct new problems with the update, I’m stuck. When we try to run the program, an error 44085 “Library Expecting Version 2009, 1.0.0” keeps appearing. After continually pressing continue, I get an Error 7 “Call Library Function Node in DriverStarion.lvlib:Start Communication.vi->Untitled 1”. After stopping we get Error 63192 “_nirio_device_open.vi:1”. We reimaged cRIO twice, and got the same problem.
This looks like you have the latest software on your PC, but not on the cRIO. 1.0.0 is the final FPGA revision. Can you verify that you reimaged with FRC_2009_v11.zip successfully? The FPGA version and revision are printed to console at boot if you have the console out toggle switch set to On. You can also ftp to the cRO and look at the frc image version text file.
I also have the same problem. I’ve updated the cRio, labview and the DS. Still can’t deploy.
When you updated the cRIO, did you format it? If it took thirty seconds, you forgot to hit the checkbox to format. Formatting takes about fifteen minutes.
Greg McKaskle
