I updated a Raspberry Pi microSD from FRCVision to the latest WPILibPi release, and was reconfiguring the network settings so that the Pi uses a static IP instead of the default DHCP. When I set it to writable, change the settings, and hit save on the Network Settings tab, it doesn’t save. If I close the web dashboard and open it back up again, the changes are gone. I can save things just fine on other tabs, and I’ve been able to make this change before in previous versions of the image. Anyone having the same problem/know what’s up/know what I’m doing wrong?
