We tried to connect as in previous years with a static 10.TE.AM.61 ip address on the laptop and ethernet cable hooked directly to roboRIO. Uploading code through Eclipse would fail. We found out:
- roboRio had a 172.22.11.2 address only, no 10.TE.AM.# address. Pinging roboRIO-TEAM.local would NOT return ipv4 appropriate ip of 10.TE.AM.#
- Discovered that the new networking is all DHCP which is being done by the wireless bridge.
- There is a wireless bridge utility in the labview folder on the laptop after installing the 2015 NI update.
- Once you hook up laptop to bridge you will get an appropriate 10.TE.AM.# ip address that is DHCP assigned.
- Once the roboRIO is hooked up to bridge it gets an appropriate 10.TE.AM.# as well.
- The mDNS will ping back an appropriate ipv4 ip address of 10.TE.AM.# for roboRIO-TEAM.local.
- Code will upload through Eclipse.
Just an FYI for any Java teams starting to program late in the build season. I hope this saves you some time troubleshooting.
