Your kit includes two E4P-360-250-D-H-D-B. These are miniature optical encoders with two-channel quadrature outputs. They are 360 codes per revolution and fit on a 0.25" shaft. See the E4P web page.
So how are they suppose to fit?
And if they do fit then they should fit directly on CIM’s output shaft since the diameter of that shaft is 5/16" right? And are E4P able to keep up with 1:1 CIM full power?
Thanks
I’m pretty sure the small end diameter referred to on that AM page is the small bearing seat before the further step down to the encoder shaft. I haven’t run across any AM shafts that don’t have the proper 1/4" shaft for an encoder, if they have one.
And yes, if properly installed, the E4P is easily capable of keeping up with the output of the CIMple box.
Thanks!
I think we will turn down the end of the shaft to 0.250". since they have tolerance of 0.020" we just need to turn it down by 1 mm. Filing the ends should do it.
