We can’t find the camera on photonvision networktable, just as the image shows. We can call the camera out on the smartdashboard and it doesn’t seem to be the camera’s problem. We’re now using a Microsoft HD-3000 camera and have it connected to roboRIO and our Raspberry Pi connected to the radio and roboRIO. Does anyone know how to solve this problem? Thank you!
What happens when you go to the cameras tab?
It just keeps processing like in the dashboard tab and we can’t choose the correct camera.
It might just need to wait a while, if it still doesn’t work, then I’m not sure I can help
Sometimes doing a power cycle works.
One thing my team has done is use a minirouter to check networking issues, wiring both a computer and the PI to the router as a middleman. you should then be able to see if your camera will connect
Your camera needs to be connected to the Pi.
We did try to connect the USB camera to our Pi however we still can’t see it either on the networktable or the smartdashboard. We’re wondering if we got the wiring wrong. How exactly do you connect the camera to the Pi?
