I’m probably doing something dumb, but I’m having trouble getting data from our Nav X over USB. I’ve got the code trying to read from serial port kUSB2, and when the code starts I either get no reading at all, or something nonsensical (e.g., 650 degrees for pitch). If I unplug the NavX and plug it into the other USB port, after a couple of seconds the data starts updating and makes sense. If I reset the the Robo Rio (leaving the same code), again the NavX doesn’t provide data. With the code still running, if I remove the USB cable from the current port and put it back in the first port, it starts working again.
I have a NavX classic and a RoboRio 2.0. I’ve tried different cables with the same result. I’ve connected the NavX to the PC and confirmed with the NavXUI app that the NavX functions properly.
Do I need to add code to configure the USB ports? I don’t think we’ve had to do that in the past and I don’t see it in the NavX example code.
Thanks for the assistance.
