Use both joysticks to drive robot on Xbox controller?
How can I use both thumb sticks on an Xbox controller to move the robot’s left and right motors?
robotDrive.tankDrive(xboxController.getRawAxis(1), xboxController.getRawAxis(3))
You can also try this:
robotDrive.tankDrive(xboxController.getY(Hand.kLeft), xboxController.getY(Hand.kRight));
What we did was define two variables as joysticks on the same port
From there use the Joystick.setChannel() method to change it to the y axis on the other stick. It should be channel 5.
after that it should work.
Sorry, I’m a bit confused about what you’re doing.
Bad idea. Why do you need to do this?
Can you post your code please?
What 18gillespiery recommends is below. I do not recommend teams do this. Instead use either of the examples above.
Once again, this code is not recommended!
	private RobotDrive drive;
	private Joystick joystick1;
	private Joystick joystick2;
	@Override
	public void robotInit() {
		drive = new RobotDrive(0, 1);
		joystick1 = new Joystick(0);
		joystick2 = new Joystick(0);
		joystick2.setAxisChannel(AxisType.kY, 5);
	@Override
		drive.tankDrive(joystick1, joystick2);
Okay, thank you all for your help!
