Use the GRIP source to get boolean value.
I can publish a boolean from the rio and see the state change on the online table viewer tool. I cant for the life retrieve it on the kangaroo running GRIP. Grip is publishing contoursreports and video so i know there is some life. When selecting add source I’m prompted with.
[text box] /
[Selectbox]Select a data type (Boolean, Number, String)
You need to provide the full path of the key in the text box. For example, if you have the boolean mapped to the key “my_bool” in the table “GRIP”, the path should be “/GRIP/my_bool”
I did have that at one time. It is possible that at that time myContoursReport was not updating as well. I assumrd that if i had a picture the Networktables were updating but noticed later that data was frozen. I habe to look more into it tomorrow.
Ok This is working now. Can I have two pipelines with two camera feeds and select what Pipeline runs to save CPU time or will I have to live with it and move on.
