User Code Critique
Hello everyone, I was just cleaning up the user code for this years 'bot, but I did it in notepad… so I’m not completely up on the syntax. I looked over it the best I could, but I would like some help so that I don’t have to debug it when I go in on Monday. I would also like to know If I am using “SetRelay” correctly, and if there is anything that is done just plain sloppy/ how to fix it. Any help would be GREATLY appreciated :smiley:
Thank you,
-Cody C.
unsigned char check;
unsigned char topcheck;
\*---------------------------ramp control-------------------------------*/
if (p3_sw_top == 1 && topcheck == 0);            // Press top button, kick cylinder extends; press top button cylinder retracts
    SetRelay ( 2 , 1 ,0 ) ;
    topcheck==1;
else if (p3_sw_top == 1 && topcheck == 1);
    SetRelay ( 2 , 0 ,1 ) ;
    topcheck==0;
if (p3_sw_trig == 1 && check == 0);              // Press trigger... Hippo folds down and ramp folds out; Press again, reset.
    SetRelay ( 3 , 1 ,0 );
    SetRelay ( 4 , 0 , 1 );
    SetRelay ( 5 , 1 ) ;
    check==1;
else if (p3_sw_trig == 1 && check == 1);
    SetRelay ( 3 , 0 ,1 ) ;
    SetRelay ( 4 , 1 , 0 );
    SetRelay ( 5 , 0 ) ;
    check==0;
/*----------------------------Arm control------------------------------------*/
if (p4_sw_aux1 == 1);                 // if top red switch is up, Hippo is up and Jaw is closed
    SetRelay ( 4 , 1 , 0 ) ;
    SetRelay ( 5 , 1 )
if (p4_sw_aux1 == 0);                // if top red switch is down, Hippo is down and Jaw is open
    SetRelay ( 4 , 0 , 1 ) ;
    SetRelay ( 5 , 0 )
if (p4_sw_aux2 == 1);                // if bottom red switch is up, Hippo is down and Jaw is closed (ramp down)
    SetRelay ( 5 , 1 )
/*-------------------------Shifting-------------------------------------------*/
if (p4_sw_top == 0 && p3_sw_trig == 0);        // if shifter is in Bottom position, servos are in position 1
    pwm05=0;
if (p4_sw_top == 1 && p3_sw_trig == 0);        // if shifter is in Middle position, servos are in position 2
    pwm05=127;
if (p4_sw_top == 1 && p3_sw_trig == 1);        // if shifter is in Top position, servos are in position 3
    pwm05=255;
The obvious problems have been fixed:
if (p3_sw_top == 1 && topcheck == 0)            // Press top button, kick cylinder extends; press top button cylinder retracts
    topcheck = 1;
    topcheck = 0;
if (p3_sw_trig == 1 && check == 0)              // Press trigger... Hippo folds down and ramp folds out; Press again, reset.
    check = 1;
    check = 0;
if (p4_sw_aux1 == 1)                 // if top red switch is up, Hippo is up and Jaw is closed
    SetRelay ( 5 , 1 );
if (p4_sw_aux1 == 0)                // if top red switch is down, Hippo is down and Jaw is open
    SetRelay ( 5 , 0 );
if (p4_sw_aux2 == 1)                // if bottom red switch is up, Hippo is down and Jaw is closed (ramp down)
    SetRelay ( 5 , 1 );
if (p4_sw_top == 0 && p3_sw_trig == 0)        // if shifter is in Bottom position, servos are in position 1
    pwm05=0;
if (p4_sw_top == 1 && p3_sw_trig == 0)        // if shifter is in Middle position, servos are in position 2
    pwm05=127;
if (p4_sw_top == 1 && p3_sw_trig == 1)        // if shifter is in Top position, servos are in position 3
    pwm05=255;
I haven’t seen a “setRelay” function before, so I can’t help you there.
Well, first of all you shouldn’t have semicolons after each if, that is bad. The comment was mixed up. You had a backwards slash and it should have been a forwards slash. You were also forgeting semicolons after some statements. The last thing I saw was you used == to assign when == is used to compare. = is used to assign. I formated it for you and fixed some errors. Here you go.
    /*---------------------------ramp control-------------------------------*/
      SetRelay(2, 1, 0);
      topcheck = 1;
      SetRelay(2, 0, 1);
      topcheck = 0;
      SetRelay(3, 1, 0);
      SetRelay(4, 0, 1);
      SetRelay(5, 1);
      check = 1;
      SetRelay(3, 0, 1);
      SetRelay(4, 1, 0);
      SetRelay(5, 0);
      check = 0;
      SetRelay(4, 1, 0);
      SetRelay(5, 1);
      SetRelay(4, 0, 1);
      SetRelay(5, 0);
      SetRelay(4, 0, 1);
      SetRelay(5, 1);
      pwm05 = 0;
      pwm05 = 127;
      pwm05 = 255;
