Has anyone tried using two cameras? If so, how do you get the two different images , because it seems that I am only allowed to set one instance of camera.
I have set on camera to 10.xx.yy.11 and the other to 10.xx.yy.12.
I can ping both cameras so the connections should be fine.
You could possibly switch between the two while running, but this might be a slow process. I would suggest moving any graphical code off the classmate.
In the SMARTDASHBOARD we are able to use two cameras. Put both of them on seperate IPs and configure the correct IPs on the dashboard and they’ll work fine.
