We have a magnetic encoder mounted to a test motor and, using the magnetic encoder example code, we get a nice sawtooth signal that gives us a position. However, we cannot just calculate the speed of the motor using (current_position - last_position)/time because we would calculate an erroneous speed when the position loops from 360 degrees to 0 degrees.
Any ideas on how to work around this to calculate the speed of the motor?
Can’t you just WPILib’s encoder VIs? Encoder Get has an output for rate, which is scaled accordingly to Distance Per Count (which you set when you opened the encoder in Begin.vi). That should do it for you.
For future reference, I would not recommend using a magnetic encoder to get the speed of a motor. While the readings are smooth, there aren’t enough voltage changes in a second to differentiate enough between speeds.
