Using Apache Commons
I’m trying to use the apache commons math library in our robot code. Is it possible to install it as a vendordep in vscode? If so how would I do this?
Just add this line to the dependencies block inside your build.gradle:
compile "org.apache.commons:commons-math3:3.6.1"
Do you also have to add the files to the project or will just adding that line work?
No. You should rarely need to manually add any files or jars to a java project. Just make sure you are connected to the internet and run a build when you add that line.
You should use implementation instead of compile. compile is the deprecated version.
