Using camera
We don’t know if we can use two cameras, can someone clarify us on that. What I mean is two different cameras on the robot
We have used multiple cameras on the robot in the past and had no problem, rules-wise. If you plan to stream them in the same time back to the driver station you might hit the bandwidth limit though.
There is no rule that would prevent this, I inspected a team a few years back that had 7. They were controlled and used for different sensing during a match. With that said please review R704 and the blue box as well.
We added a second Limelight using only the Camera for finding Cargo. It is an easy way to add Imaging to the Driver Station. However in our case, it took out the Targeting for one Match. A TSA found the problem for us… Thanks for all their help. [Go GEMS]
