Using Interrupts
I’m having problems using interupts…
i don’t understand them…
i have read the manual from IFI, and read kevin’s code, but i still can’t really get how is should use them…
could someone please post a bit of code showing how to use kevin’s interrupts?
Thanks!
-Leav
hi,
what do you need the interrupts for? usually encoders. if so, take a look at Mr. Watson’s encoder template. It has interrupts already set up for left and right drives. all you have to do is call the functions. also, take a look here. this is where I was utterly confused about encoders.
http://www.chiefdelphi.com/forums/showthread.php?t=32611&highlight=encoder
