Hey, so my team is looking for ways to make the RPM function to be more precise. We are currently using linear interpolation in Excel. However we feel that probably a more real function could be achieved, and thought of calculating a parabola. How could we possibly achieve that, and is it worth it?
You want a polynomial regression of order 2.
P.S. if you weren’t finding answers on Google, it’s spelled quadratic, not cuadratic
To what RPM function are you referring?
In any case, to do a smoother interpolation function that actually passes through your data points, you may want to try cubic splines.
http://mathworld.wolfram.com/CubicSpline.html
I’d recommend using desmos Graphing calculator. It has a built in regression calculator with any equation type you want. We use it for regressions all the time and it’s super easy to use.
I second this. Desmos has a very powerful regression tool. You can run a regression based on any type of equation, and can run multivariable regressions.
I actually found/implemented code to calculate cubic spline interpolations on the reo. The code is here https://github.com/phlogiston1/frc-3461-2020/blob/master/src/main/java/frc/lib/math/CubicSplineInterpolate.java you do need the Jama libraries for matrices but if you take them from the folder on our GitHub it only has the parts required for the interpolation.
