V13 Master Code
Here is the new version of the master code for the 04-07 controllers.
FRC_MASTER_V13.zip (13.9 KB)
How do you update the master code in the robot controller?
In easyC goto the terminal window then under the options menu select “Update Master Code” then specify a path to the .bin file.
In the IFI loader just hit browse and then select .bin for the file type and specify the path to the .bin file.
